logo
Multi-Site Search
September 02, 2010, 09:25:19 PM *
News:
Digg This!
Pages: [1]   Go Down
  Print
Author Topic: Fixing rotted balsa end grain in deck  (Read 879 times)
Frank Hagan
Administrator
Member
Offline Offline
Photo Album
View Profile WWW
« on: July 30, 2006, 09:29:20 PM »
Anyone have experience fixing rotted balsa end grain core material?  There's a Potter owner who is planning to drill holes every few inches and pour in thinned epoxy as a way of fixing the problem.  I'm not sure this is the solution, and I thought some of our more experienced members might know a way to fix this kind of problem.  His plan is at http://bbs.trailersailor....tter/index.cgi/read/55039 and he is seeking as much free advice as possible!
Logged
Charlie Jones
Pro Builder
Member
Offline Offline
Photo Album
View Profile WWW
« Reply #1 on: July 30, 2006, 11:00:25 PM »
I've been watching the thread Frank. Ray and others have pretty well covered it. I didn't see any need to add more.
But it never hurts to get more thoughts. Hey, I don't know it all, that's for sure. Very Happy
Logged
first row, third coast
Frank Hagan
Administrator
Member
Offline Offline
Photo Album
View Profile WWW
« Reply #2 on: July 31, 2006, 01:48:21 AM »
I only saw his thread in the Potter board over there, so didn't know if you guys had chimed in on it yet.  I'll have to start reading the main forum over there again when things settle down ... any day now, any day now ....
Logged
Oyster
« Reply #3 on: July 31, 2006, 07:17:06 AM »
I was in a new 19 about a month ago. It seems to be so open, that a repair could be done and hidden from the outside, messing up the finish coat. This is if the owner plans on keeping the boat. I would emagine that there is several sections that are worse than others, and he could maybe get the worse out from an opening in the underside of the deck, if accessible. in the worse areas There are ways that you can acheive a finish for the overhead, without working completely overhead by fabricating panels, and do the finish work off the boat, and just use decrative mouldings to cover the cut sections. I would also think that doing this in stages would not render the boat useless, either.
Logged
PAR
Builder &
Naval Architect
Member
Offline Offline
Photo Album
View Profile
« Reply #4 on: January 15, 2009, 05:27:25 PM »
The usually repair is to drill holes (typically 1/8" on 2" centers) and fill with neat epoxy. Do not use thinned epoxy, CPES or other reformulated thinned epoxy. You're just waiting time and money.
For the repair to work the core has to be able to return to it's original or better compression strength and (most importantly) it has to be very well bonded to the inner and outer skins, without prospect of sheering. The use of thinned epoxy will guarantee it will sheer it's skins and delaminate in the future.
As Ray mentioned the core has to be below 15%, which can take several months, depending on conditions. The rotted areas of core must be removed (no Get-Rot doesn't fix the rotten wood, nor does CPES), the whole of all contact and bond areas cleaned, then abated. Then you can apply good quality laminating epoxy.
If just drilling holes and not exposing the core (harder, takes longer and you have hundreds of holes to repair), then mix milled fibers and silica at 50/50 to inject into the holes.
It's usually more cost effective to cut off one of the skins over (or under) the affected area, remove the soaked and rotten core, clean, abate and bond in a new core, then bond the old skin back down. A lot less patching to do and the work can be done very quickly.
Logged
Hirilondė
Member
Offline Offline
Photo Album
View Profile
« Reply #5 on: January 16, 2009, 09:29:15 AM »
The subject of wet coring comes up a lot in http://www.plasticclassicforum.com/ .  Do a search there and you will find numerous threads on the subject.  I suggest paying particular attention to comments made by "Tim". the forum administrator and a professional fiberglass boat renovator.
In a nutshell that is by far the best way.  Anything else is just a quick fix and prone to failure, if it even does anything at all.  Moisture trapped in the core will virtually never dry out.  And even if it did, you will never rebond the core to the skins effectively.
"Nothing is more permanent than a temporary fix".
Logged
Dave Finnegan
Pearson Renegade "Hirilondė"
Spindrift 9N # 521
“ The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. ”
— Bertrand Russell
Pages: [1]   Go Up
  Print
Jump to:
Related Topics
Deck Fastening B & B Yachts Forum Brent 4 654 Last post April 18, 2003, 05:14:44 PM
by Pat Kelly
Deck is on Main Forum Andrew 4 402 Last post August 14, 2003, 08:56:12 AM
by Stuart Benbow
CS 20 DECK ON.. B & B Yachts Forum Rob Blackburn 0 589 Last post August 24, 2003, 08:16:18 PM
by Rob Blackburn
To deck or not to deck? B & B Yachts Forum Jeff Horton 2 693 Last post April 25, 2004, 02:42:50 PM
by Jeff Horton
Aft deck, or not aft deck, that is the question... B & B Yachts Forum Scott Dufour 4 751 Last post July 16, 2004, 12:19:58 PM
by mustangermatt
Opinions about end grain exposure. B & B Yachts Forum Brian Watford 6 671 Last post October 10, 2004, 09:58:31 AM
by Joe Nelson CS#35
Finishing: Home Made Grain Filler General Woodworking Frank Hagan 4 1752 Last post October 19, 2005, 12:16:10 PM
by Frank Hagan
Bowsprit grain alignment Main Forum Joel 9 630 Last post June 28, 2007, 06:49:09 AM
by capt jake
fixing my boat again.. ugh, what a mess B & B Yachts Forum Eric 12 1450 Last post January 17, 2009, 09:23:08 PM
by Tom Lathrop
Valid XHTML 1.0! Valid CSS!
Mobile Version
