logo
Multi-Site Search
September 02, 2010, 09:35:25 PM *
News:
Digg This!
Pages: [1]   Go Down
  Print
Author Topic: Voids in plywood question  (Read 640 times)
Pipefitter
Member
Offline Offline
Photo Album
View Profile WWW
« on: March 31, 2006, 01:26:00 AM »
I keep hearing about voids in plywood. I can almost understand why this might make it bend funny but it seems it would have to be quite large.As far as condensation forming within the plys,how is this possible?I mean,why would this occur moreso in a boat than say hanging on the side of a building or on the floor of a house? Are these voids not encased in the gluelines of the plywood? If exterior grade plywood has waterproof glue,wouldn't this take a long time? I was always told upon questioning a builder's using marine grade fir exterior for a workboat, that I would spend more time repairing damage from scratches with rocks or oysters or getting sanded from beach landings then I would fixing a rotten void.He claimed if I found rotten wood in a boat soon enough,it was no more than cutting in a cold patch(neat little trick he showed me using multiple sizes of hole saws where the wooden puck has a rabbet and the hole cut in the boat has a rabbet as well, creating a male and female part with a large glue area)that is glued in place and glassed over.
Maybe this void issue means more on a boat that lives in the water? How many of you have seen rotten voids in plywood?
Logged
Wishing I was fishing and when I'm fishing I am wishing I was catching.
Tom Lathrop
Member
Offline Offline
Photo Album
View Profile
« Reply #1 on: March 31, 2006, 07:27:06 AM »
Pipeman,
Rot requires moisture and oxygen.  Take either of these away and there will be no rot.  That is why the term "dry rot" is an oxymoron and can not occur.
All wood has voids within the cellular structure.  Red oak has more than most and rots quicker than white oak which has blocking material in the veins.  Balsa is full of air so it rots very quickly.  However balsa core that is full of moisture gained by osmosis through a fiberglass skin but, is otherwise sealed from oxygen, is just wet and heavy, not rotted.
So an enclosed void by itself is only a mechanical problem and not one of rot.  Lots of boats have been built with Nomex, a honeycomb material that encloses mostly air between wood skins.  Not saying that there have not been rot problems there though.  A linear void that runs from edge to edge in plywood is the worse case since a breach anywhere along the void can let in both air and water.
I don't like voids and try to a-void them but they are probably not the buggaboo that many assume,
Logged
umop_apisdn
Member
Offline Offline
Photo Album
View Profile
« Reply #2 on: March 31, 2006, 04:53:39 PM »
Ok, I don't know much about this, but that isn't going to stop me from voicing my opinion on the subject. Smile Very Happy
I've always wondered about this too, since lots of boats use a balsa core, which is mostly air anyway.  I came to the conclusion that the problems with voids must be primarily structural or mechanical.  Small ones probably don't matter much.
That said, were I to build a boat from scratch (which I have NOT done, so take my opinion with a grain of salt), I'd still definately go with marine ply. You get more plys, stronger glue, it will bend more evenly, and have a higher strength-to-weight ratio.  The fact that is has no voids is probably a good thing, but not the main reason for choosing it, IMHO.
If you are going to invest 1000 hours of your time into something, you want it to be made out of the finest materials available.  It would really suck to have a long, straight void right in the middle of a bend, and have a "crease" appear in the hull of your boat over the top of it after a year or two....
Noel
Logged
Weekender "Lady Jeanine"
One green sail, and one white.
Arnie Eaton
Member
Offline Offline
Photo Album
View Profile
« Reply #3 on: March 31, 2006, 06:14:48 PM »
There are more grades of marine grade plywood then AA. I buy AB and pay a lot less then AA grade. The "B" side goes to the inside of the boat in most cases but can also be on the outside if you glass. There are NO voids in marine grade plywood even with one side graded "B". B grade can have plugs within the surface ply. but finishes the same as "A" side.
Logged
Builder of Wind Song, a Vacationer
Barry Pyeatt
Member
Offline Offline
Photo Album
View Profile
« Reply #4 on: March 31, 2006, 06:53:03 PM »
A recomendation if you are purchasing AB Marine and plan on glassing over one side of it.  Put the "B" side out to be glassed.  Keep the "A" side to be finished as you choose.
I see builders all the time trying to get a really nice finish on the lesser graded side when they glass over the good side.  Glass and resin don't care if it is an "A" surface or a "B" surface.  No, there isn't much difference between the sides perse', but again, down the road after some time out in the weather, it helps to have the better side inside the boat with a good face to paint rather than dealing with a plugged surface veneer.
Just a little tip from someone that hates having to repaint interiors just because the plugs  outline shows thru the paint.  Rolling Eyes
Logged
Weekender-Spirit Wind
Mukilteo, WA
Pipefitter
Member
Offline Offline
Photo Album
View Profile WWW
« Reply #5 on: March 31, 2006, 11:59:57 PM »
I would agree to get the best you can.Atleast below waterline. I hear of alot of people using MDO for it's fine surface for finishing. That paper or glass/epoxy has to be a much better veneer than even the most expensive wood. Either way it is at the least that you're gonna pay now or pay later one way or the other. I had not considered how much my time was worth when I was having to spend whole weekends sanding the lesser quality materials.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Related Topics
Plywood Scarfing? B & B Yachts Forum Joe Nelson 1 1340 Last post October 21, 2002, 09:28:23 PM
by Graham Byrnes
scarfing plywood B & B Yachts Forum Gerry 5 1442 Last post December 31, 2002, 03:33:33 PM
by Graham Byrnes
Plywood in CA B & B Yachts Forum Mike Vacanti 5 1100 Last post March 13, 2003, 08:34:51 PM
by Mike Vacanti
Plywood Main Forum Denis Goyette 0 362 Last post March 19, 2003, 02:48:14 PM
by Denis Goyette
Plywood Main Forum Denis Goyette 2 446 Last post March 19, 2003, 05:41:20 PM
by Charlie Jones
plywood B & B Yachts Forum Spinnaker55 7 861 Last post October 01, 2005, 10:28:32 AM
by Greg Luckett
Question on plywood in Thailand B & B Yachts Forum Eric 6 1506 Last post May 20, 2010, 08:07:11 PM
by LiveSteam
First plywood cut for CS 20 #67 B & B Yachts Forum Noklin 1 612 Last post January 07, 2006, 03:53:24 PM
by Designer
Plywood Main Forum « 1 2 » Toad 16 972 Last post May 20, 2009, 09:47:15 AM
by lewisboats
Epoxy-coating-plywood question B & B Yachts Forum Travis Votaw 4 736 Last post October 20, 2009, 03:24:10 PM
by Peter HK
Valid XHTML 1.0! Valid CSS!
Mobile Version
