logo
Multi-Site Search
September 02, 2010, 09:23:05 PM *
News:
Digg This!
Pages: [1]   Go Down
  Print
Author Topic: Cradle Boat Finished  (Read 1746 times)
Frank Hagan
Administrator
Member
Offline Offline
Photo Album
View Profile WWW
« on: December 11, 2005, 12:43:33 PM »
I decided to build a cradle for my grandson, to be born around Christmas this year.  The design I settled on was a dinghy, built in a "sort-of" traditional manner with copper roves and rivets, from Jordan Wood Boats (he advertises in Wooden Boat Magazine - http://www.jordanwoodboats.com).  Just like a real boat, you build a strong back first, and then lay the stem and stern post, transom and keel.
The planking comes next, and this is where my first problem started.  It is difficult to plane red oak this thin and keep it in one piece ... the porous nature of red oak makes it easy to split.  The plans call for white cedar, which would be a much easier wood to plane this thin, and then keep it from splitting as you bend it and fasten it with silicon bronze flat head wood screws (another bow to tradition that I'll never make again!)
The rivets presented a problem for me too, and I think I have them inside out ... the flat head of the rivet should be on the inside, and the rove pounded onto the outside.  Too late!  Riveting boat planks together is just another reason I'm a thoroughly modern boat builder!  Give me epoxy from now on!  But enough complaining, the bottom planks were easier ... 1/2" thick instead of 3/16" like the sides, and not much bend.
The plans include both rockers which attach directly to the bottom of the cradle, and davits to suspend it.  The construction of the davits is pretty straight forward, but I think the plan's rigging is a bit of overkill.  I think I could hang my Potter 19 from the davits!  But here are the finished pics:
For the rigging, a bridle is made to attach to the stern quarter knees with figure-8 stopper knots underneath, with a bronze double block riding on the bridle.  A bronze eye strap is positioned under the davit head, and the line is attached to it using an anchor bend.  The line is rove down to the block, up to one of the sheeves in the davit head, down to the other side of the double block and back up through the other sheeve in davit head, then down to a bronze cleat to be made fast, so as baby doesn't crash to the ground.
All in all, its been a worthwhile project.  My wife has made some great bedding for the cradle, and I'll post pictures of it with the bedding when the battery on the camera recharges!
Logged
capt jake
Member
Offline Offline
Photo Album
View Profile WWW
« Reply #1 on: December 11, 2005, 12:46:02 PM »
That is a really nice cradle you have made! I can see a lot of time, love and effort. Smile  Nice job!
Logged
Frank Hagan
Administrator
Member
Offline Offline
Photo Album
View Profile WWW
« Reply #2 on: December 11, 2005, 12:59:30 PM »
After all the sanding, which rivaled making a REAL boat, I finished the cradle with 4 coats of BLO (Boiled Linseed Oil) applied with a cloth.  To help fill the pores of the red oak and mahoghany (used for the transom, quarter knees, breasthook and keel) I used 4F pumice forced into the pores of the wood while applying the BLO ... it works great, and helps give a slightly darker hue to the wood.  The other lighter wood used is beech, which I found finishes beautifully.  It will definately find its way into more projects!
After the BLO hardened, I sealed it with a 1# cut of Garnet shellac, applied with a pad.  Then, I sprayed 4 coats of Target Coatings' "Oxford ULTIMA Spray Lacquer" in a satin finish.  ULTIMA is a water based product, and I was skeptical at first ... but it acts like a true lacquer (each subsequent coat "melts" into the one before it, so you end up with a very "deep" looking coating).  And it dries hard within about 30 minutes, ready for recoating.  This allowed me to fill the spray cup and simply clean the nozzle between sprayings.  It is easy to spray with my $99 HVLP spray unit, and the finish comes out great.
Logged
Frank Hagan
Administrator
Member
Offline Offline
Photo Album
View Profile WWW
« Reply #3 on: December 11, 2005, 01:01:38 PM »
Quote from: "capt jake"
Well, all I can say is the little guy better be cute!  I don't want an ugly baby in my cradle!
My daughter doesn't know its coming, so we're shipping it this week and will be there when it arrives.
Logged
« Reply #4 on: December 11, 2005, 03:06:34 PM »
WOW!!!!! Thats a very nice job there and hopes that folks will wonder down to take a peak at this project.
Logged
Frank Hagan
Administrator
Member
Offline Offline
Photo Album
View Profile WWW
« Reply #5 on: December 11, 2005, 03:49:45 PM »
I put the bedding my wife made for the cradle ... we wanted something nautical, but not cutesy, and I think my wife found something that works really well ...
I thought the project fit better here than in the Main Forum ... it is a boat of sorts, but this one would never float for long!
Logged
« Reply #6 on: December 11, 2005, 03:58:33 PM »
WOW, I do like that teak decking with an alternative white seam compound..  It adds a very nice touch indeed.  Laughing Great piece of woodworking, Frank. Thats something that will be enjoyed and hopefully  passed along for quite some time.
Logged
Bill
Member
Offline Offline
Photo Album
View Profile
« Reply #7 on: December 11, 2005, 08:20:09 PM »
Quote
I think you have it right. They should be from the outside in, that is, they would be nipped on the inside and the rove put on from the inside. The flat part of the rivet/nail would be on the outside.
It looks fantastic. i've always liked the looks of those projects and wanted to build one. We are, fortunately/unfortunately past the baby cradle stage in my family (extended and otherwise). I have thought about building a scaled down version for Dolls though, and it may still happen.
I'll bet your daughter gets tearful when she see's this one. A true family heirloom. All of it looks great. Well done....
b.
Logged
Frank Hagan
Administrator
Member
Offline Offline
Photo Album
View Profile WWW
« Reply #8 on: December 11, 2005, 09:54:18 PM »
Quote from: "Bill"
Quote
OK, good.  I wasn't sure, and then I thought no one in his right mind would design a baby cradle with dozens of these little sharp points pounded over roves INSIDE a baby cradle.  I ended up sanding them all very smooth ... but its good to know I did it the right way.
Quote
b.
Leah is the analytical type, so I doubt she will get teary.  I'm hoping for happy, which is a pretty safe bet with her.
Although she is pregnant, and I always thought the aliens took over my wife when she was pregnant, so its possible she could get teary.
Logged
Greg Luckett
Member
Offline Offline
St. Joseph, MI
Photo Album
View Profile
« Reply #9 on: December 12, 2005, 08:17:23 PM »
This is one, really nice cradle and is what I really wanted to build for my last grand child.  Now I am waiting for the next one to come along to give me an excuse to copy this.
Thanks for the sharing and congrats on the excellent work,
Greg.
Logged
"You don't have to think fast if you move slow." - Red Green
Barry Pyeatt
Member
Offline Offline
Photo Album
View Profile
« Reply #10 on: December 12, 2005, 11:06:24 PM »
Very nice Frank!   Great family heirloom there.
Logged
Weekender-Spirit Wind
Mukilteo, WA
Frank Hagan
Administrator
Member
Offline Offline
Photo Album
View Profile WWW
« Reply #11 on: December 27, 2005, 09:50:32 AM »
Here's the real finishing touch ... "mom" won't let me use the flash when the baby's asleep, so the pic is a bit blurry and dark.
Logged
Greg Luckett
Member
Offline Offline
St. Joseph, MI
Photo Album
View Profile
« Reply #12 on: December 27, 2005, 01:02:23 PM »
Man!, that is wonderful  Very Happy .
Logged
Pages: [1]   Go Up
  Print
Jump to:
Related Topics
Trying to get this boat finished in the fisher island sound Main Forum Zeroice 11 906 Last post August 05, 2003, 09:17:50 PM
by Anonymous
Latest Cradle Pic Main Forum Dave R1 6 570 Last post March 23, 2004, 10:32:58 PM
by Barry Pyeatt
the Cradle Boat... Main Forum Dave R1 8 508 Last post May 04, 2004, 05:48:57 AM
by Dave R1
Sea Skiff cradle Main Forum Jeff Horton 0 374 Last post October 02, 2004, 08:59:50 PM
by Jeff Horton
Almost finished building my boat trailer Main Forum « 1 2 3 » Mike Pennington 33 1369 Last post May 04, 2005, 06:15:52 PM
by Craig
Cradle Boat Main Forum Craig 3 787 Last post August 19, 2006, 06:11:36 PM
by Craig
Cradle for a CS 17 B & B Yachts Forum John C 3 1050 Last post October 05, 2006, 07:57:05 AM
by Tom Lathrop
New boat finished! With pics . . . . Main Forum DGentry 12 1241 Last post May 01, 2009, 09:30:20 AM
by DGentry
Another boat finished . . . . Main Forum DGentry 5 483 Last post June 04, 2009, 11:22:09 AM
by DGentry
Finished boat B & B Yachts Forum hrg 3 691 Last post January 12, 2010, 08:00:47 PM
by hrg
Valid XHTML 1.0! Valid CSS!
Mobile Version
