logo
Multi-Site Search
September 02, 2010, 09:22:06 PM *
News:
Digg This!
Pages: [1]   Go Down
  Print
Author Topic: Stich and glue  (Read 749 times)
Antony Harvey
Member
Offline Offline
Photo Album
View Profile
« on: September 22, 2004, 05:13:16 PM »
I am about to start a Princess 22, having built one traditionally framed plywood boat. Is there anything I can dowload that explains the technique and materials? Are there many ways of going about it? Am I opening a bag of worms?
Logged
Charlie Jones
Pro Builder
Member
Offline Offline
Photo Album
View Profile WWW
« Reply #1 on: September 22, 2004, 05:27:00 PM »
As long as you read Graham's instructions closely and FOLLOW them, you should have little difficulty other than the normal ones of building a 22 footer.
If you have never done a stitch and glue boat before, I think I'd suggest building a small dinghy first. B and B has some very nice ones. I built the Minipaw myself. It's a good beginning and won't take a lot of time or money. Give you some experience with the technique.
I'm in the completion phases of a Princess 22 right now. If you use the search function and use "Princess 22" as your criteria you'll find a lot of pictures I've posted during the construction.
Logged
first row, third coast
Joe Nelson CS#35
Member
Offline Offline
Photo Album
View Profile
« Reply #2 on: September 22, 2004, 09:55:22 PM »
Devlin's Boatbuilding book would be a good investment.  It will provide you with basic knowledge of materials and tools, as well as the building process.
Logged
Joe Nelson
CS20 #35
Garry
Member
Offline Offline
Photo Album
View Profile WWW
« Reply #3 on: September 23, 2004, 04:15:37 PM »
It's really pretty easy. Follow the advice given above and you should have it mastered soon. One advantage of the stitch-and-glue method is that you don't want to stitch the seams up tight until eaverything is pieced together. Then you slowly snug each stitch a little at the time pulling each piece into position and making adjustments as needed. If you need to recut, simply unstitch, rework as needed, and stitch it back together. Then you starting the fillet process which can also be reversed, if needed, but takes more work.
The stitch-and-glue process is very forgiving to learn as you go. But I agree that you should pop together a dinghy first before tackling a 22 footer.
Logged
The adventure continues! or Begin...the rest is easy!
Birder 2
thinking of Core Sound 15 or 17
dreaming of Princess 28
sold Spindrift 11N, Pied Piper 28, Allied Princess 36 ketch
« Reply #4 on: September 23, 2004, 04:59:48 PM »
To add several thoughts concerning this method, handling mixes batches of glue and fillers for the fillets will take some getting use to, in the beginning. Mixed in bulk or sitting in a mass as in the mixing cups, will kick off quicker than recommended working times. Don't try to do big amounts in the beginning. You will have plenty of working time when mixing small quantities.. We spread it out on a short piece of plywood, or plywood and a slick surface of formica, that helps slow the mixes from kicking, and to allow for you to work the mixes better after the initial mixing of the fillers. Make the fillets as neat as possible, cleaning up as you go. Keep some vinegar around to clean your tools during working times, and have on hand extra whatever that you are using to switch out, if you are working alone.  This one issue has frustarted many new comers when dealing with the expensive stuff in the beginnign of their project.
Logged
Michel Goudeseune
Member
Offline Offline
Photo Album
View Profile WWW
« Reply #5 on: September 24, 2004, 09:02:20 AM »
Just to add to Oyster's comments about mixing quantity: I've found it's much easier to mix two batches of 2 ounces, than to mix one batch of 4 ounces, especially if you're thickening the epoxy.  It doubles your working time, too -- the second batch is fresh, while the first is already starting to thicken.  So you get more time to get things right.
One other epoxy tip: keep a notepad on the workbench.  EVERY time you mix up a batch of epoxy, write down the time, volume, and ratio of thickeners.  Otherwise, you will not remember exactly when you mixed the current batch, and how much working time you have left.  My log entries look something like this:
April 17 -- center frame
17:03         1 floz thin
17:10         1 floz, 4:2:1 epoxy/flour/cabosil
etc
[thin: straight epoxy; 4:2:1: 1 floz epoxy, 0.5 floz wood flour, 0.25 floz cabosil]
Hope this helps,
Michel
Logged
Pages: [1]   Go Up
  Print
Jump to:
Related Topics
glue for keel Main Forum richard 8 507 Last post June 09, 2003, 08:52:43 AM
by Mark Hughes
hull #97 almost ready to stich B & B Yachts Forum mustangermatt 6 570 Last post October 24, 2003, 09:07:53 PM
by Designer
Stich and glue 2 B & B Yachts Forum Antony Harvey 9 741 Last post September 25, 2004, 10:36:33 PM
by Frank Hagan
Glue: Waterproof, smaterproof! Main Forum Frank Hagan 0 273 Last post March 19, 2005, 12:47:29 PM
by Frank Hagan
Weldwood Glue Main Forum mrthethird 10 629 Last post November 25, 2005, 12:47:19 PM
by Dave Fleming
Screws with glue Main Forum Pipefitter 12 694 Last post March 31, 2006, 09:39:28 AM
by Pipefitter
Stich & Glue construction for a TOTAL NOVICE B & B Yachts Forum bananawind 8 1153 Last post April 20, 2006, 06:41:17 AM
by John Turpin
Gorilla Glue ?? Main Forum OWM 12 1241 Last post August 05, 2007, 08:02:26 AM
by Greg Luckett
Glue question Main Forum « 1 2 » kormorant2 24 1141 Last post December 27, 2007, 05:51:57 AM
by Greg Luckett
Titebond wood glue vs. epoxy glue B & B Yachts Forum Richard Whitney 6 848 Last post March 21, 2009, 11:30:22 PM
by PAR
Valid XHTML 1.0! Valid CSS!
Mobile Version
